[gdal-dev] How to recognize FDO style SQLite db?
Jukka Rahkonen jukka.rahkonen at maanmittauslaitos.fi
Fri May 27 05:51:24 PDT 2016
Even Rouault <even.rouault <at> spatialys.com> writes:
> This probably doesn't completely fullfil the requirement of "simple mean" ,
> but if you enable the debug messages from GDAL with "--debug on", you should
> see :
> "OGR style SQLite DB found !"
> whereas a Spatialite one will trigger :
> "SpatiaLite v4 DB found !" (or "Spatialite DB found" for spatialite 2 or 3)
Simple enough, I'll try to find some place to document that in
http://www.gdal.org/drv_sqlite.html.
-Jukka-
