[gdal-dev] Building GDAL on Windows 32 and 64 bit
Dmitry Baryshnikov bishop.dev at gmail.com
Fri May 27 08:03:10 PDT 2016
Hi Alex,
The work is done taking into considerations this link:
https://trac.osgeo.org/gdal/wiki/CMake
Also, there were some ideas about gdal source code reorganisation in
dev-list.
This is second turn of cmakefication of GDAL.
The lib_gdal repository synced with gdal trunk periodically (there is a
python script in etc folder
(https://github.com/nextgis-borsch/lib_gdal/blob/master/etc/cmake-build-helpers/gdal_restructure.py)
to do it). Now the sources are 2.1 release version. The different GDAL
version support will be added in future.
I think current lib_gdal is not ready to switch trunk (not all drivers
ready, not all bindings ready, etc.), but very close (see
https://github.com/nextgis-borsch/lib_gdal/blob/master/README.md about
work status).
Best regards,
     Dmitry
27.05.2016 14:56, alex пишет:
>>> [Alex]
>>> Is there a convention about where to place and how to name the win32 and
>> x64
>>> libraries and include directories when building for both platforms on
>>> Windows?
>>> Especially, I would like CMake's FindGDAL
>>> (https://cmake.org/cmake/help/v3.0/module/FindGDAL.html) to be able to
>> find
>>> the correct paths automatically.
>> [Dmitry Baryshnikov]
>> Hi,
>> It seems to me there is no standard install path on Windows, so search
>> GDAL is tricky.
>> CMake can register package in registry and so find GDAL, but GDAL have
>> to be CMaked too.
>> You may try our CMake GDAL (https://github.com/nextgis-borsch/lib_gdal).
>> In your project only need to add find_anyproject(GDAL), see -
>> https://github.com/nextgis-borsch/borsch.
>> GDAL will be downloaded, build and linked with your project.
> Hi Dmitry,
> Thanks, that looks very useful and addresses a major headache. I am a bit reluctant to include further dependencies and straying from the 'official' GDAL repository and processes.
> Is there any chance that your efforts will make it to a future GDAL release?
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
