[gdal-dev] gdal_translate issues downloading GeoTIFF with TMS/WMTS/AGS
Stefan Keller sfkeller at gmail.com
Mon May 30 06:01:49 PDT 2016
My goal is to download a GeoTIFF with highest resolution over a
small(!) region [see 1] out of a raster tile server/service.
I have two issues with this command which uses AGS (see [2]; could be
any other WMTS or TMS):
gdal_translate -of GTiff gdal_tiles_openstreetmap.xml osm_mapnik3.tif
-projwin 8.810788393 47.2283918446 8.8263881207 47.221163925
-projwin_srs epsg:4326 -co TILED=yes -co COMPRESS=JPEG -tr 0.1 0.1
1. What I get, is a result made of tiles from zoom level 17 or so. But
I'd like to get the highest resolution i.e. from zoom level 19 (and
"-tr 0.1 0.1" does not help with that): How can I do that?
2. Is there an option to slow down http requests (like 10 per sec.) in
order to save resources of the service? (Should I write an issue?)
(Finally I will reproject the GeoTIFF to a local SRS using gdalwarp.)
:Stefan
[1] http://tools.geofabrik.de/calc/#type=geofabrik_standard&bbox=8.810788393,47.221163925,8.8263881207,47.2283918446&tab=1&proj=EPSG:4326&places=2
[2] --- ::: File gdal_tiles_openstreetmap.xml ::: --
<GDAL_WMS>
    <Service name="AGS">
        <ServerUrl>https://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer</ServerUrl>
        <ImageFormat>png32</ImageFormat>
        <Transparent>true</Transparent>
        <ImageSR>102100</ImageSR>
        <Layers></Layers>
        <BBoxOrder>xyXY</BBoxOrder>
    </Service>
    <DataWindow>
        <UpperLeftX>-20037508.34278700</UpperLeftX>
        <UpperLeftY>20037508.34278700</UpperLeftY>
        <LowerRightX>20037508.34278103</LowerRightX>
        <LowerRightY>-20037508.34278103</LowerRightY>
        <SizeX>40075016</SizeX>
        <SizeY>40075016</SizeY>
    </DataWindow>
    <BlockSizeX>512</BlockSizeX>
    <BlockSizeY>512</BlockSizeY>
    <Projection>EPSG:3857</Projection>
    <BandsCount>4</BandsCount>
    <ClampRequests>true</ClampRequests>
    <UserAgent>Mozilla/5.0</UserAgent>
    <ZeroBlockHttpCodes>499,204,404</ZeroBlockHttpCodes>
    <ZeroBlockOnServerException>true</ZeroBlockOnServerException>
</GDAL_WMS>
