[gdal-dev] Building GDAL on Windows 32 and 64 bit
Joaquim Luis jluis at ualg.pt
Tue May 31 06:03:51 PDT 2016
> Again, I can only speak from experience.  I wish that magically I am
> wrong for GDAL, and cmake on Windows is maintained for each and every
> GDAL driver :)  (whoa that is a big wish)
> -jeff
Jeff,
Life doesn't have to be so painful with Cmake on Windows. For example in
GMT we use a optionally include ConfigUser.cmake where one can define
dependencies that are built in non-cmake ways.
For example to add the GDAL dependency I define this in ConfigUser.cmake
file. Here the the ${VC} and ${BITAGE} are just variables used to select
different VS versions and "bitages".
So not all the dependencies need to be build with Cmake too.
   # set location of gdal (can be root directory, path to header file or
path to gdal-config):
   set(GDAL_DIR "C:/programs/GDALtrunk/gdal/compileds/${VC}_${BITAGE}")
   set(GDAL_LIBRARY
"C:/programs/GDALtrunk/gdal/compileds/${VC}_${BITAGE}/lib/gdal_i.lib")
Joaquim
