[gdal-dev] Next maintenance releases
Even Rouault even.rouault at spatialys.com
Tue May 31 13:20:56 PDT 2016
Looking at https://trac.osgeo.org/gdal/roadmap, I thought we could issue RCs
for 1.11.5, 2.0.4 and 2.1.1 for end of June.
As the transition to 2.X is well engaged in depending apps/libs, 1.11.5 will
probably be the last one in the 1.11 series.
Even
http://www.spatialys.com
