[gdal-dev] Simple circle in OGR
Renison rex200789 at gmail.com
Thu Nov 3 09:51:28 PDT 2016
Forgot to add that this is not a pure circle per-se, it is a polygon
comprised of 10000 points on the circumference of the buffer from the
reference point. I have used WGS84 projection for source circle and checking
the concerned OGR geometry.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Simple-circle-in-OGR-tp5294053p5294219.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
