[gdal-dev] Question on gdalwarp, srcnodata and dstalpha
Daniele Romagnoli daniele.romagnoli at geo-solutions.it
Thu Nov 3 10:19:36 PDT 2016
Hi List,
I was checking a gdalwarp (GDAL 2.1.2) invokation with a colleague and I
have a question.
I know that when warping a geotiff with internal NODATA_VALUES=0 0 0
metadata, only RGB pixels = 0 0 0 are handled as nodata whilst pixels like
"0 2 4", "50 0 0" will not right?
In the past, I had issues using -scrnodata 0 instead of embedded
NODATA_VALUES=0 0 0, getting results with sparse nodata around due to
band_i = 0 being interpreted as a nodata pixels. This is why I usually
suggest to define the NODATA_VALUES metadata to make sure only the exact
triplet is handled as nodata.
However, today we have processed a simple UTM RGB dataset (without
NODATA_VALUES metadata defined) using this command:
gdalwarp -t_srs EPSG:4326 -srcnodata 0 -dstnodata None -dstalpha
And the result is properly rendered: the alpha mask is zero only where the
input pixels are "0 0 0" which is exactly what we needed.
Do something has been changed in the latest versions? Is the alpha band
mask being set to zero only when all input pixels are zero?
Thanks for the clarification.
Cheers,
Daniele
Ing. Daniele Romagnoli
Senior Software Engineer
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:      +39 0584 1660272
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161103/ec78246a/attachment.html>
