[gdal-dev] GDAL WMTS Driver - How do you control the Tile Matrix Set's Tile Level?
jratike80 jukka.rahkonen at maanmittauslaitos.fi
Sun Nov 6 23:11:42 PST 2016
Did you forget to include your request? Or do you mean that you asked
gdal_translate just to convert the whole data source that you defined with
that xml file into some other format without defining the window by using
-spat or -projwin?
-Jukka Rahkonen-
View this message in context: http://osgeo-org.1560.x6.nabble.com/GDAL-WMTS-Driver-How-do-you-control-the-Tile-Matrix-Set-s-Tile-Level-tp5294530p5294539.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
