[gdal-dev] gdal on freebsd
Mike Toews mwtoews at gmail.com
Mon Nov 7 15:10:19 PST 2016
On 7 November 2016 at 21:33, Jyrki Von Karkki
<jyrki_von_karkki at mailbox.org> wrote:
> Hi all
> I'm having a bit of an issue with the postgresql/postgis driver on freebsd.
> It simply does not appear installed.
How did you install GDAL? The PostgreSQL driver is not always
available since it not compiled by default.
If you are compiling GDAL from source, see --with-pg=ARG from the
configure script. Also be sure to have the development headers for
libpq.
