[gdal-dev] DODS driver (packagers recommended to disable it)
Sebastiaan Couwenberg sebastic at xs4all.nl
Tue Nov 8 23:12:16 PST 2016
Via Launchpad issue #1640360 [0] I was informed about a segfault in the
DODS driver when fed a JSON URL. In the related IRC discussion packagers
are recommended to disable the DODS driver. [1]
Is the DODS driver so error prone to make this recommendation?
The driver has been enabled for a very long time in the gdal Debian
package, so I'm surprised about the recommendation to disable it now.
The GDAL_SKIP=DODS env var seems like a fine workaround for this
specific issue, since the Launchpad issue is the first to report issues
with it. If the OpenEx function handles other JSON data correctly, and
only fails for the proprietary arcgis service, that doesn't seem like a
good a reason to disable the DODS driver which would disadvantage its users.
[0] https://bugs.launchpad.net/ubuntu/+source/gdal/+bug/1640360
[1] http://irclogs.geoapt.com/osgeo/%23osgeo.2016-11-09.log
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
