[gdal-dev] How to replace an osm key?
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Fri Nov 11 09:46:46 PST 2016
If you select geometry and attribute "foo" that's all you get. If you want attribute "bar" as well you must do "select geometry,foo,bar from your_table". That is plain SQL, you will find tutorials from the web.
-Jukka-
Lähettäjä: Djordje Spasic<mailto:issworld2000 at yahoo.com>
Lähetetty: ‎11.‎11.‎2016 19:10
Vastaanottaja: Rahkonen Jukka (MML)<mailto:jukka.rahkonen at maanmittauslaitos.fi>; gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Aihe: Re: [gdal-dev] How to replace an osm key?
Thank you Jukka.
I understand now why I need to repeat the same syntax 4 times (by only changing multipolygon/multilinestrings/lines/points).
Can you explain this part as well please:
> You must edit the SQL parameter to include all the fields that you want to get into the result  "select geometry, building as bldg, another_attribute as attr_2 …”
On Friday, November 11, 2016 4:04 PM, Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi> wrote:
“Building” tag can exist in any layer. It is controlled with the osmconf.ini file https://svn.osgeo.org/gdal/trunk/gdal/data/osmconf.ini
It is true that by default it is selected only for multipolygons. However, I suppose that in the native OSM data the building tag is sometimes used also on points and relations (other_relations for GDAL). I also aimed at a general answer that could be useful for all tags and layers in OSM data.
-Jukka Rahkonen-
Lähettäjä: Djordje Spasic [mailto:issworld2000 at yahoo.com]
Lähetetty: 11. marraskuuta 2016 16:38
Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>; gdal-dev at lists.osgeo.org
Thank you for the reply Jukka.
> and you must run the query separately for all the layers ( points, lines, multilinestrings, multipolygons).
What does this part mean?
That I need to call ogr2ogr.exe four times:
ogr2ogr.exe --config OSM_USE_CUSTOM_INDEXING NO -skipfailures -f "ESRI Shapefile" -dialect sqlite –sql "select geometry, building as bldg from multipolygons” output.shp input.osm
ogr2ogr.exe --config OSM_USE_CUSTOM_INDEXING NO -skipfailures -f "ESRI Shapefile" -dialect sqlite –sql "select geometry, building as bldg from points” output.shp input.osm
ogr2ogr.exe --config OSM_USE_CUSTOM_INDEXING NO -skipfailures -f "ESRI Shapefile" -dialect sqlite –sql "select geometry, building as bldg from lines” output.shp input.osm
ogr2ogr.exe --config OSM_USE_CUSTOM_INDEXING NO -skipfailures -f "ESRI Shapefile" -dialect sqlite –sql "select geometry, building as bldg from multilinestrings” output.shp input.osm
Doesn't "building:..." key (field) only exist among the multipolygons?
I didn't understand you this part either.
The "select geometry, building as bldg, another_attribute as attr_2 …” part needs to include only those keys (fields) which I would like to get changed? Not all the others which I would like to have them remain the same as in original .osm file?
If I misunderstood you, can you please provide an example syntax?
Thank you, and my apology for further disturbance.
Djordje
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161111/c7eccac9/attachment-0001.html>
