[gdal-dev] How to replace an osm key?
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Sat Nov 12 01:29:18 PST 2016
Related to your previous question, you can use SQL select only for fields which are included in osmconf.ini. Perhaps "height" is not. 'building:levels' may make a surprise for you, if ogr2ogr follows SQL specification it will select a fixed string. You should use double quotes instead and they may require escaping but I do not remember with which character. Start with easy test and more attributes with odd names one by one.
-Jukka-
Lähettäjä: Djordje Spasic<mailto:issworld2000 at yahoo.com>
Lähetetty: ‎12.‎11.‎2016 3:37
Vastaanottaja: Rahkonen Jukka (MML)<mailto:jukka.rahkonen at maanmittauslaitos.fi>; gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Aihe: Re: VS: [gdal-dev] How to replace an osm key?
Hi Jukka,
I have just tried to rename the fields with SQL. Here is the syntax:
"C:\gdal\ogr2ogr.exe" --config OSM_USE_CUSTOM_INDEXING NO -skipfailures -f "ESRI Shapefile" -dialect sqlite -sql "select geometry, building as bldg, 'building:levels' as bldg_level, height as height from multipolygons" output_shps input.osm
It raises the following error message:
ERROR 1: In ExecutableSQL<>: sqlite3_prepare<select geometry, building as bldg, 'building:levels' as bldg_level, height as height from multipolygons>:
no such column: height
Interestingly when I convert an .osm file to .shp files without using the SQL syntax, then the multipolygons.shp file does contain the "height" field. Not all shapes inside it contain it, but some do.
So why is the upper "no such column: height" error message raised?
Is something wrong with the SQL syntax?
Thank you for the reply.
Kind regards,
Djordje
On Friday, November 11, 2016 6:46 PM, Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi> wrote:
If you select geometry and attribute "foo" that's all you get. If you want attribute "bar" as well you must do "select geometry,foo,bar from your_table". That is plain SQL, you will find tutorials from the web.
-Jukka-
Lähetetty: ‎11.‎11.‎2016 19:10
Aihe: Re: [gdal-dev] How to replace an osm key?
Thank you Jukka.
I understand now why I need to repeat the same syntax 4 times (by only changing multipolygon/multilinestrings/lines/points).
Can you explain this part as well please:
> You must edit the SQL parameter to include all the fields that you want to get into the result  "select geometry, building as bldg, another_attribute as attr_2 …”
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161112/7106afb1/attachment-0001.html>
