[gdal-dev] Ogr2ogr -dim and Oracle
Michael Smith michael.smith.erdc at gmail.com
Thu Nov 17 04:05:25 PST 2016
For the srid, I would say keep that as an srs doesn't always map cleanly to an srid.
Sent from my iPhone
> On Nov 17, 2016, at 5:54 AM, Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> I would also check how ogr2ogr options –a_srs and –t_srs  behave or if the OCI driver option –lco SRID is still needed.
> -Jukka-
> Lähettäjä: Michael Smith [mailto:michael.smith.erdc at gmail.com]
> Lähetetty: 17. marraskuuta 2016 13:49
> Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>
> Kopio: 'gdal-dev at lists.osgeo.org' (gdal-dev at lists.osgeo.org) <gdal-dev at lists.osgeo.org>
> Aihe: Re: [gdal-dev] Ogr2ogr -dim and Oracle
> Yes even the current version needs the layer creation option for dim. I would be +1 for this change (never really understood why it was this way). I think we are probably one of the biggest users of the oracle driver and I think this would be a good improvement.
> Sent from my iPhone
> On Nov 17, 2016, at 2:06 AM, Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> I noticed that Even was editing the ogr2ogr help about the –dim parameter and  remembered that I think that it does not have an effect on the OCI driver. For forcing a new Oracle table into 2D you must use the OCI drivers own layer creation option “DIM” instead http://www.gdal.org/drv_oci.html. I am not sure if that happens also with the current GDAL version.
> -Jukka Rahkonen-
> gdal-dev mailing list
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161117/89368564/attachment-0001.html>
