[gdal-dev] Recommended lib Curl version for GDAL 2.1.2 and WMTS
esacree esacree at knology.net
Thu Nov 17 12:37:52 PST 2016
Which version of libCurl is recommended for use with GDAL 2.1.2 and the
GDAL_WMTS driver?
We have been using libCurl version 7.45 dated 7-Oct-2016.  The newest
version is 7.51 dated 2-Nov-2016.  7.51 contains a very long list of fixes.
The upgrade could be time consuming to rebuild everything.  We thought we
should ask if it is needed for GDAL_WMTS.  It appears to be set up correctly
but the WMTS server returns transparent images.  That could indicate an HTTP
issue with libCurl.
Thanks!
Elaine
View this message in context: http://osgeo-org.1560.x6.nabble.com/Recommended-lib-Curl-version-for-GDAL-2-1-2-and-WMTS-tp5296336.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
