[gdal-dev] Why are fields required in osmconf.ini file?
jratike80 jukka.rahkonen at maanmittauslaitos.fi
Thu Nov 17 23:54:49 PST 2016
georges wrote
> Thank you for the quick reply Even!
> So this required predefined set of fields is a necessary step for any .osm
> file conversion with ogr2ogr.exe?
> Not only conversion from .osm to .shp?
> But also to .pbf, geojson etc. ?
Only exception and highly recommended if you want to get all the tags is to
use PostGIS and "all_tags" which puts everything into hstore:
ogr2ogr -f PostgreSQL "PG:dbname=osm" test.pbf -lco
COLUMN_TYPES=all_tags=hstore
-Jukka Rahkonen-
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Why-are-fields-required-in-osmconf-ini-file-tp5296342p5296397.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
