[gdal-dev] Why are fields required in osmconf.ini file?
Djordje Spasic issworld2000 at yahoo.com
Fri Nov 18 01:17:41 PST 2016
Thank you for the useful reply Jukka!
The command you gave me:
ogr2ogr -f PostgreSQL "PG:dbname=osm" test.pbf -lco
COLUMN_TYPES=all_tags=hstore
does the same thing as "all_tags=yes" in the osmconf.ini file:
# uncomment to create "all_tags" field. "all_tags" and "other_tags" are exclusive
all_tags=yes
If not, then what is the difference between these two?
    On Friday, November 18, 2016 8:55 AM, jratike80 <jukka.rahkonen at maanmittauslaitos.fi> wrote:
 georges wrote
> Thank you for the quick reply Even!
> So this required predefined set of fields is a necessary step for any .osm
> file conversion with ogr2ogr.exe?
> Not only conversion from .osm to .shp?
> But also to .pbf, geojson etc. ?
Only exception and highly recommended if you want to get all the tags is to
use PostGIS and "all_tags" which puts everything into hstore:
-Jukka Rahkonen-
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Why-are-fields-required-in-osmconf-ini-file-tp5296342p5296397.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
gdal-dev mailing list
gdal-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161118/30ad61af/attachment.html>
