[gdal-dev] CAD (DWG) Driver
Even Rouault even.rouault at spatialys.com
Sat Nov 19 06:18:22 PST 2016
On samedi 19 novembre 2016 16:52:09 CET Dmitry Baryshnikov wrote:
> Hi,
> I fixed all reported by Even and Kurt errors and recommendations in CAD
> (DWG) driver and most of recommendations in OpenCAD library. The pull
> request (https://github.com/OSGeo/gdal/pull/164) passed all the checks
> successful. It seems to me the driver is ready to merge to the trunk.
> This will simplify testing and reviewing the new driver by community.
> There are some problems in big_endian and xcode CI tests, because of
> C++11 compiler flags (not a problem of CAD driver code, etc.) - I
> disable C++11 (and appropriate the CAD driver too) in this tests. It
> seems to me that not blocking issue and I can merge the code to trunk.
> Are there any objections?
Massive +1
I've just noticed your comment https://github.com/OSGeo/gdal/pull/
164#issuecomment-261525037 about the issue with C++11 in the GeoTIFF driver.
I've just fixed that code, so you can now likely re-enable C++11 in the
big_endian and mac envs
http://www.spatialys.com
