[gdal-dev] Unable to extract features from KML
Michael Z Freeman michael-gdal at michaelzfreeman.org
Mon Nov 21 10:35:03 PST 2016
Thanks for this !
I eventually realised that I'd got in a muddle because I had failed to
understand what "wkb_geometry" is (
https://en.wikipedia.org/wiki/Well-known_text ). I think I thought it was
the gdal way for setting the SRID or something like this. So after seeing
the light I am using ...
ogr2ogr -f PostgreSQL PG:"dbname=original_hirise" -nlt geometry
MC-01-0-0-0_1.kml
SELECT ST_AsText(wkb_geometry) FROM mc_01_0_0_0_1;
... shows ...
GEOMETRYCOLLECTION(POINT(-30.415 88.0473),POLYGON((-28.14 87.938,-31.75
87.9205,-32.947 88.1536,-28.884 88.1731,-28.14 87.938))).
I'll be using PHP so the multigeometry should be fine for the moment and
seems easy enough to access ...
SELECT * FROM mc_01_0_0_0_1 WHERE
ST_DWithin(ST_CollectionExtract(wkb_geometry, 1),
ST_SetSRID(ST_MakePoint(-30.332,87.4992), 4326), 0.2);
... which gives two results with the correct coordinates.
Sorted ! (as we say here).
Best
Michael Z Freeman
On Mon, November 21, 2016 7:30 am, jratike80 wrote:
> Hi,
> The main problem is that KML support such data models which do not suit
> well with the simple feature model of GDAL. You can get some information
> about that by reading http://www.gdal.org/drv_libkml.html.
> In your case each feature has two geometries: one point and one polygon.
> Best that can be done with the simple feature model it to push them both
> into one geometry which in that case must be a geometry collection. Here
> is one example from your data
> GEOMETRYCOLLECTION (POINT (-1.282 87.1064),POLYGON ((3.02457
> 87.0792,2.22294
> 86.9806,-5.655 87.1168,-5.098 87.2201,3.02457 87.0792)))
> You can save geometry collections into PostGIS if you use ogr2ogr with
> switch "-nlt geometry". However, saving geometry collections into PostGIS
> may not solve your problem because only few GIS programs can handle
> geometry collections well.
> A better option for you might be to explode the collections and save
> points and polygons as separate features into PostGIS. The ogr2ogr command
> to use is like
> ogr2ogr -f PGDump output_pgdump -nlt geometry -explodecollections
> Beyer_Hirise_Areas_KML/MC-01-0-0-0.kml
> If you want to have a quick look at your data, use JML as outputformat
> and open the result with OpenJUMP. It shows both the geometry collections
> and exploded collections fine for me with names and descriptions.
> -Jukka Rahkonen-
> http://osgeo-org.1560.x6.nabble.com/gdal-dev-Unable-to-extract-features-f
> rom-KML-tp5296670p5296708.html Sent from the GDAL - Dev mailing list
> archive at Nabble.com. _______________________________________________
> gdal-dev mailing list gdal-dev at lists.osgeo.org
