[gdal-dev] cppcheck
Even Rouault even.rouault at spatialys.com
Wed Nov 23 06:28:50 PST 2016
On mercredi 23 novembre 2016 05:43:44 CET Kurt Schwehr wrote:
> Even,
> Thank you for your work with getting cppcheck setup and fixing a huge
> number of warnings (and suppressing a large number of false positives)!!!
I encourage you as well to extend the tooling so as to check that all the cleanups you do do
not regress. I guess you must have some ad-hoc scripts. If there were available, that would at
least enable new developments to meet those standards. And if they don't pass on the
whole code base, I guess it would be possible to run them on white-listed directories (or
exclude black-listed directories)
QGIS has a scripts/prepare-commit.sh that handles mostly code formatting (reformatting it
automatically), but something similar that would handle formatting and/or other checks
could be useful.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161123/c6b833f5/attachment.html>
