[gdal-dev] "Very" long path name support under windows
Bugbuster
philippe.ghesquiere at airbus.com
Wed Nov 23 08:57:55 PST 2016
Hi Even,
thanks for your long and detailed answer. I have plenty of information I can
play around with.
In fact, I managed to "cd" to the desired directory within a *Cygwin Mintty*
windows. In this window, I do not have the "8.3 Windows renaming". In that
way, I mimicked what I get with a system call from a JAVA program.
I will try to see what we can do with the /"utilities as library methods"
way/ as you say. We just need to upgrade to Gdal V2.1 :-)
Thanks again for your help.
Philippe
View this message in context: http://osgeo-org.1560.x6.nabble.com/Very-long-path-name-support-under-windows-tp5297074p5297164.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
