[gdal-dev] "Very" long path name support under windows
Damian Dixon damian.dixon at gmail.com
Wed Nov 23 09:09:58 PST 2016
Hi Even, Philippe,
Windows has two types of paths.
The first is essentially the codepage and is about 260 characters.
The second is the unicode pathname which is probably around 32k characters.
I can't remember the actual limit.
The cmd line and explorer only use the 260 character limit.
So a unicode program can create a path that is not particularly useable via
the cmd line or via explorer. cygwin bash shell works though.
You have to use the win32 unicode versions of the file open etc... to use
the nice long paths.
Regards
Damian
On 23 November 2016 at 16:57, Bugbuster <philippe.ghesquiere at airbus.com>
wrote:
> Hi Even,
> thanks for your long and detailed answer. I have plenty of information I
> can
> play around with.
> In fact, I managed to "cd" to the desired directory within a *Cygwin
> Mintty*
> windows. In this window, I do not have the "8.3 Windows renaming". In that
> way, I mimicked what I get with a system call from a JAVA program.
> I will try to see what we can do with the /"utilities as library methods"
> way/ as you say. We just need to upgrade to Gdal V2.1 :-)
> Thanks again for your help.
> Philippe
> View this message in context: http://osgeo-org.1560.x6.
> nabble.com/Very-long-path-name-support-under-windows-
> tp5297074p5297164.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161123/cf8d4cbf/attachment.html>
