[gdal-dev] Troubleshooting palette management. Potential bug in palette for overviews?
Daniele Romagnoli daniele.romagnoli at geo-solutions.it
Thu Nov 24 07:51:59 PST 2016
Doh!
Thanks for the feedback, Even. (Indeed it seemed strange to me that nobody
had ever noticed before)
Best Regards,
Daniele
On Thu, Nov 24, 2016 at 1:35 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Daniele,
> This is indeed an inconsistency I spotted a long time ago :
> https://trac.osgeo.org/gdal/ticket/2213
> Nobody was apparently sufficiently annoyed by this to fix it. Actually I
> see I proposed a patch. Was probably waiting for feedback. I'm not sure if
> there's a standardized way of converting between the [0,255] and [0,65535]
> ranges.
> Even
> > Hi List,
> > I'm investigating on a issue I have with a paletted image with overviews,
> > using java ImageIO tiff reader (wait... I know on this list we discuss
> > about GDAL topics :) ).
> > I'm trying to better understand palette interpretation and palette
> storing
> > on tags and how they are handled by GDAL.
> > From TIFF specifications, colormap entries are stored as short values.
> > I have a sample file with this color tab (as reported by gdalinfo).
> > Color Table (RGB with 256 entries)
> > 0: *164*,164,164,255
> > 1: *255*,255,255,255
> > 2: 0,0,0,255
> > 3: 0,0,0,255
> > .... repeat 0,0,0,255 to the end.
> > Using an Hex editor or AsTiffTagViewer, I can see the byte values of the
> > colormap as stored on the file.
> > For the first 4 mappings of the colortable the Red components are:
> > *A4 A4* *FF FF* 00 00 00 00
> > (8 bytes = 4 shorts)
> > As far as I have understood, this is related to that part of the
> > specification (quoting it, section 5):
> > *In a TIFF ColorMap, all the Red values come first, followed by the Green
> > values, then the Blue values. In the ColorMap, black is represented by
> > 0,0,0 and white is represented by 65535, 65535, 65535*
> > So the second entry of the map, being white (255, 255, 255) has its red
> > value stored as 65535 = *FF FF *whilst the first color (164,164,164) has
> > its red value stored as 42148 = *A4 A4*
> > I see this behavior is confirmed by the way the geotiff.cpp create the
> > colortable:
> > https://github.com/OSGeo/gdal/blob/trunk/gdal/frmts/gtiff/
> geotiff.cpp#L5043
> > panTRed[iColor] = static_cast<unsigned short>(257 * sRGB.c1);
> > panTGreen[iColor] = static_cast<unsigned short>(257 * sRGB.c2);
> > panTBlue[iColor] = static_cast<unsigned short>(257 * sRGB.c3)
> > Applying a color*257 multiplication allows to have its 8 bits color
> > representation stored into a short where intensity goes from 0 to 65535.
> > The issue I have is that when using gdaladdo, the overviews are generated
> > with a different color table.
> > So that the first 8 bytes of the red component stored in the colormap,as
> > reported by AsTiffTagViewer are:
> > *A4* 00 *FF* 00 00 00 00 00
> > When converting it back to a 0-255 color component with the formula
> > R*255/65535 it become *163* instead of 164.
> > I see in the GDAL code that both the IBuildOverviews and
> > CreateOverviewsFromSrcOverviews call the CreateTIFFColorTable function
> > which multiplies the colorMapEntry by 256 instead of 257.
> geotiff.cpp#L9137
> > This may explain the *A4* 00 *FF* 00 entries in the overview with respect
> > to the *A4 A4 FF FF *entries in the main level.
> > Do you have any feedback on this?
> > Please, let me know what do you think about it.
> > Best Regards,
> > Daniele
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Ing. Daniele Romagnoli
Senior Software Engineer
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:      +39 0584 1660272
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161124/eb3ada45/attachment.html>
