[gdal-dev] ogr python: copying features from postgis to postgis
Stefan Ziegler stefan.ziegler.de at gmail.com
Sat Nov 26 12:18:50 PST 2016
Hi
I'm trying to copy some features from one postgis table to another postgis
table:
dstLayer.StartTransaction()
srcFeature = srcLayer.GetNextFeature()
while srcFeature is not None:
    srcLayerDefn = srcLayer.GetLayerDefn()
    dstLayerDefn = dstLayer.GetLayerDefn()
    dstFeature = ogr.Feature(dstLayerDefn)
    dstFeature.SetFID(-1)
    for i in range(0, dstLayerDefn.GetFieldCount()):
        attrName = dstLayerDefn.GetFieldDefn(i).GetNameRef()
        # ATTRIBUTES
        try:
            attrVal = srcFeature.GetField(attrName)
            dstFeature.SetField(attrName, attrVal)
        except ValueError:
            pass
    # GEOMETRY
    geom = srcFeature.GetGeometryRef()
    dstFeature.SetGeometry(geom)
    # ADD FEATURE
    dstLayer.CreateFeature(dstFeature)
dstLayer.CommitTransaction()
It throws an error when trying to create the new feature:
GNM: GNMRegisterAllInternal
GNM: RegisterGNMFile
GNM: RegisterGNMdatabase
PG: DBName="xanadu2"
PG: PostgreSQL version string : 'PostgreSQL 9.5.4 on x86_64-pc-linux-gnu,
compiled by gcc (Ubuntu 5.4.0-6ubuntu1~16.04.2) 5.4.0 20160609, 64-bit'
PG: PostGIS version string : '2.2 USE_GEOS=1 USE_PROJ=1 USE_STATS=1'
GDAL: GDALOpen(PG: host=localhost dbname=xanadu2 user=stefan
password=XXXXXXXXXX this=0x11e41b0) succeeds as PostgreSQL.
PG: Command Results Tuples = 11
GDAL: GDALDriver::Create(Memory,,0,0,0,Unknown,(nil))
PG: 11 features read on layer 'sql_statement'.
password=XXXXXXXXXX this=0x12db330) succeeds as PostgreSQL.
PG: Primary key name (FID): t_id, type : int8
PG: Using column 't_id' as FID for table
'nachfuehrngskrise_nachfuehrungskreis'
  File "./datenumbau.py", line 117, in <module>
  File "/usr/local/gdal_master/lib/python2.7/site-packages/osgeo/ogr.py",
line 1479, in CreateFeature
    return _ogr.Layer_CreateFeature(self, *args)
RuntimeError: OGR Error: General Error
GDAL: GDALClose(PG: host=localhost dbname=xanadu2 user=stefan
GDAL: In GDALDestroy - unloading GDAL shared library.
GDAL: Force close of  (0x136abb0) in GDALDriverManager cleanup.
Mem: 1 features read on layer 'sql_statement'.
I'm bit confused about the "general error". Does anyone has an idea?
regards
Stefan
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161126/c93ebf55/attachment.html>
