[gdal-dev] Reading KML tree using LIBKML driver
Matthias Meulien orontee at gmail.com
Sun Nov 27 14:27:29 PST 2016
I am trying to recover the tree structure of KML folders while
reading  a dataset created from a .kml  or a .kmz file with the LIBKML
driver.
My idea is to loop through the dataset layers and maintain a mapping
from kmldom::ElementPtr to  layers
    std::map<kmldom::ElementPtr, OGRLayer*> parents;
Each layer, say l1, is cast to OGRLIBKMLLayer; its associated
kmldom::ElementPtr is read using OGRLIBKMLLayer::GetKmlLayer() and a
search is performed for one of its ancestor in the parents mapping...
Is there a simpler way to recover the tree structure of KML files?
Until now I've only obtained partial results using this approach :-(
The following naive implementation works for dataset coming from a KML
file:
    for (int i = 0; i < dataset->GetLayerCount(); ++i) {
        auto* const layer = dataset->GetLayer(i);
        auto* const kmlLayer = static_cast<OGRLIBKMLLayer*>(layer);
        kmldom::ElementPtr element = kmlLayer->GetKmlLayer();
        kmldom::ElementPtr ancestor = kmlLayer.GetParent();
        std::map<kmldom::ElementPtr, OGRLayer*>::iterator s =
parents.find(ancestor);        while ((s == std::end(parents)) &&
ancestor) {
            kmldom::ElementPtr temp = ancestor->GetParent();
            ancestor = temp;
            s = parents.find(ancestor);
        if (s != std::end(parents)) {
            // Ok layer's parent is s->second
        } else {
            // layer is a root folder
        parents[element] = layer;
But it crashes on ancestor = temp when the source file is a KMZ file...
Any clue?
Matthias
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161127/1d99c59b/attachment.html>
