[gdal-dev] Multithread deadlock
Francisco Javier Calzado francisco.javier.calzado at ericsson.com
Mon Oct 3 02:34:39 PDT 2016
Thank you so much Even. It is working like a charm!
-----Original Message-----
From: Even Rouault [mailto:even.rouault at spatialys.com]
Sent: 30 September, 2016 01:05
To: gdal-dev at lists.osgeo.org
Cc: Francisco Javier Calzado <francisco.javier.calzado at ericsson.com>
Subject: Re: [gdal-dev] Multithread deadlock
> I don't think this comes from GDALPam, but rather from the lower level
> machinery of GDALRasterBand & GDALRasterBlock. As I said before,
> multi- threaded writing has never properly worked and I'm not sure if
> the issue you see is just an implementation bug or a design bug.
OK, after investigation, it was just an implementation bug. A lack of mutex in
GetLockedBlock() that caused IReadBlock() & IWriteBlock() to be called from 2 different threads on the same dataset.
Fixed per https://trac.osgeo.org/gdal/ticket/6665
I think the issue was mostly due to using the low level
GetLockedBlock()/MarkDirty()/DropLock() interfaces, and that people using
RasterIO(GF_Read/GF_Write) should be immune to that bug due to locks being already taken at that stage.
Anyway fixed now (with a new test case similar to yours). Thanks for the reproducers.
Even
Spatialys - Geospatial professional services http://www.spatialys.com
