[gdal-dev] Gdal_grid with a mask layer?
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Thu Oct 6 03:54:38 PDT 2016
I have depth data from a lake as scattered points and I would like to convert them into raster DEM.  Unfortunately this lake is not a rectangular, north oriented one but it has a curvy shoreline and lots of islands. In my first trials the resulting DEM leaks away from the water to the dry ground. I guess that some other algorithms than the invdist would give better results near the shoreline. Generating fake zero depth points on the ground area would probably help with all the algorithms. However, what I would like to do is to define a mask layer for telling the valid area for the DEM that will be generated.  Is that possible somehow? If it is not then other good tricks are welcome. The good result should have zero depth on the ground and sharp shoreline at correct place.
-Jukka Rahkonen-
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161006/044ab274/attachment.html>
