[gdal-dev] Need suggestion on clipping vectors in batch
Even Rouault even.rouault at spatialys.com
Thu Oct 6 06:25:32 PDT 2016
Le jeudi 06 octobre 2016 14:47:05, Margherita Di Leo a écrit :
> Dear Even,
> On Wed, Oct 5, 2016 at 8:53 PM, Even Rouault <even.rouault at spatialys.com>
> wrote:
> > Tiny Python script with GDAL 2.1 :
> > from osgeo import gdal
> > src_ds = gdal.OpenEx('your.shp')
> > lyr = src_ds.GetLayer(0)
> > minx, maxx, miny, maxy = lyr.GetExtent()
> > # Note the different order of bounds between previous and next line
> > gdal.VectorTranslate("out.shp", src_ds, \
> >  spatFilter=(minx + DX,miny +DY,maxx-DX, maxy-DX))
> > Many thanks!
> I'm having some headache because I have gdal 1.11 installed system-wide,
> coming from package, so I installed gdal 2.2 in local in $HOME/opt/gdal
> (=$GDAL_INSTALL_DIR)
> in my terminal I run:
> $ export PATH=$GDAL_INSTALL_DIR/bin:$PATH
> $ export LD_LIBRARY_PATH=$GDAL_INSTALL_DIR/lib:$LD_LIBRARY_PATH
> $ export GDAL_DATA=$GDAL_INSTALL_DIR/share/gdal
> $ gdalinfo --version
> GDAL 2.2.0dev, released 2016/99/99
> $ python
> >>> gdal.VersionInfo()
> '1110400'
> Also, in sys.path() the $GDAL_INSTALL_DIR is listed correctly... I'm at a
> dead end :-/
Try:
export PYTHONPATH=$GDAL_INSTALL_DIR/lib/python2.7/site-packages
( adapt the path to the python version you use)
http://www.spatialys.com
