[gdal-dev] New GMLAS (GML Application Schema) in trunk
Even Rouault even.rouault at spatialys.com
Sat Oct 8 05:03:40 PDT 2016
Just to inform you I've commited an initial version (read-only for now, write
support to come) of the OGR GMLAS driver into trunk. This driver can read XML
files of (almost) arbitrary structure, included those containing so called
Complex Features, provided that they are accompanied by one or several XML
schemas that describe the structure of their content. While this driver is
generic to any XML schema, the main target is to be able to read documents
referencing directly or indirectly to the GML namespace, such as GML documents
conforming to Inspire or GeoSciML schemas.
The connection string is GMLAS:/path/to/the.gml
More on http://gdal.org/drv_gmlas.html
Even
http://www.spatialys.com
