[gdal-dev] Outdated external overviews
jratike80 jukka.rahkonen at maanmittauslaitos.fi
Tue Oct 11 07:34:58 PDT 2016
Hard to say if such use case exists. Perhaps if .ovr is actually not
subsampled from the main data at all but tweaked from let's say 1:50000
scale raster maps when the main maps are 1:20000.  I have created such
overview stacks sometimes through .vrt. I am not sure if the automatic
invalidating would have any effect in that case.
-Jukka Rahkonen-
Even Rouault-2 wrote
> Julien,
>> Thanks for your response. I understand all your points, and that Gdal
>> requirements usually fall far beyond our limited use cases ...
> I was mostly playing the devil advocate. I don't have in mind real world
> use
> cases that would rely on .ovr being potentially older that the main file,
> while
> still considering them valid (anyone having such use cases ?). And I'd
> suspect
> they are probably very niche use cases, compared to the cases where the
> main
> image has been refreshed but an outdated overview file is hanging around.
> On the other hand, my main fear with your proposal would be timestamp
> issues
> when copying datasets around that could make GDAL think that an .ovr is
> outdated whereas it is not. But that's perhaps a unusual case too.
> (That said we have already timestamp based logic in the GML driver where
> the
> OGR generated .gfs file is only taken into account if more recent than the
> .gml. I can remember having had issues with that with the autotest suite
> that
> have required adding an explicit touch of the .gfs file before running the
> test. Might be just a SVN / git thing, or perhaps the content of the .gml
> was
> indeed minorly edited after the .gfs had been created.)
> Thinking loud: would a USE_EVEN_IF_OLDER_THAN_MAIN_FILE=YES/NO metadata
> item
> added to the .ovr would make sense to determine the later behaviour ? I
> dunno.
> If folks are sufficiently aware to set this metadata to YES (assuming the
> new
> default would be NO), then they might as well touch the .ovr file after
> modifying the main file.
> Anyway if you feel strong about changes in that area that have
> implications
> regarding backward compatibile behaviour, a RFC would be appropriate.
> Even
>> We can of
>> course do a lot in the client code (starting with comparing timestamps),
>> but this is not specific to our software, I bet Qgis for instance will
>> happily use outdated overviews without notice. This is why I am
>> wondering if it could not be handled more cleanly at the Gdal level. I
>> understand though that this is not an easy problem to fix.
>> Regards,
>> Julien
>> Le 07/10/2016 à 16:46, Even Rouault a écrit :
>> > Hi Julien,
>> >> I recently came accross an issue in our software which uses overviews
>> to
>> >> speed-up navigation in image : the image can change after an external
>> >> overview has been generated (for instance it has been re-generated by
>> an
>> >> upstream processing chain with different parameters), this can lead to
>> >> display bugs or even crash in client code (if for instance the number
>> of
>> >> bands has changed)
>> > Are the crashes you mention occuring in GDAL ? If so that should be
>> > fixed. From a quick try, RasterIO() requests that involve overviews
>> > trigger a proper error if the .ovr has less bands than the full
>> > resolution dataset. Of course if client code directly uses
>> > GetOverview(), it must be careful to check for NULL pointer.
>> >> . Of course this is not a problem for the user that
>> >> knows what she is doing : simply removing and generating the overview
>> >> again fixes the problem. But for software that offers overview
>> >> generation to the end user, this might become an issue, as the
>> software
>> >> has no clue wether the ovr file is outdated or not.
>> >> Possible mecanism to prevent this would be :
>> >> - Check file last modification time between external overview and
>> image
>> >> file. If image file is newer than overview files, it is probably
>> >> outdated.
>> > "Probably" yes :-) But I can imagine workflows where the overviews are
>> > not necessarily a subsampling of the full resolution dataset, in which
>> > case such behaviour wouldn't be desirable. I'm also wondering if that
>> > wouldn't cause problems when datasets are copied. Hopefully timestamps
>> > should be preserved most of the time, but I guess you could find
>> > situations where they are not and where the overview could be copied
>> > before the main dataset.
>> >> - Encode image checksum in ovr file, and compare it upon loading
>> (might
>> >> be a bit intensive).
>> > We definitely don't want to do that on gigabyte sized datasets...
>> >> With those checks, gdal could detect that the ovr file is outdated and
>> >> simply ignore it. Then client code could be aware that there are
>> >> actually no overviews for this image and take actions to generate new
>> >> ones.
>> > The client code can also use the GDALDataset::GetFileList() API and see
>> > if there's a .ovr file listed in there. And thus decide to apply a
>> > timestamp based logic if it whishes.
>> > Or one could imagine to put that logic into GDAL itself, but I think
>> that
>> > should be an option explicitly set.
>> > There would be a subtelty also. Imagine that the external overview is
>> > outdated, and you want to update it, but not recreate it from scratch.
>> > For example if you know which area has been updated in full resolution
>> > dataset. Then you'd want the overview to be still accessible. So hiding
>> > the overview should only apply for datasets opened in read-only mode.
>> >> PS: This of course does not apply if overviews are internal
>> > You probably meant that detecting that overviews are outdated is even
>> > less doable than for the external case, but that situation can still
>> > happen.
>> > Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at .osgeo
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Outdated-external-overviews-tp5289792p5290252.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
