[gdal-dev] FW: Function - GDALCreatePansharpenedVRT
Even Rouault even.rouault at spatialys.com
Mon Oct 17 07:14:26 PDT 2016
Jidnyasa,
Please let the list CC'ed (I've re-added it)
> Thanks for the reply. My doubt is if I am having only panchromatic and
> multispectral files as an input how to generate pansharpening vrt without
> using python script as I am trying to use only C++?
Well 2 choices:
1) port
https://svn.osgeo.org/gdal/trunk/gdal/swig/python/scripts/gdal_pansharpen.py
to C++. That shouldn't be too hard. It mostly formats the XML of the VRT and
finally pass it to GDALCreateCopy
2) or perhaps less cumbersome, use the lower level C++ pansharping API of
alg/gdalpansharpen.h ( http://www.gdal.org/gdalpansharpen_8h.html )
Even
> Thanks & Regards,
> Jidnyasa N
> -----Original Message-----
> From: Even Rouault [mailto:even.rouault at spatialys.com]
> Sent: Monday, October 17, 2016 2:40 PM
> To: gdal-dev at lists.osgeo.org
> Cc: Jidnyasa Nilange <jidnyasa.nilange at advancedriskanalytics.com>
> Subject: Re: [gdal-dev] FW: Function - GDALCreatePansharpenedVRT
> Hi,
> >               I am trying to use  GDALCreatePansharpenedVRT  function
> > however I am not been able to interpret the argument const char *
> > pszXML
> >  Which is explained as  "Pansharpened VRT XML where <SpectralBand>
> > elements have no explicit SourceFilename and SourceBand. The spectral
> > bands in the XML will be assigned the successive values of the
> > pahInputSpectralBands array. Must not be NULL."
> > Can someone please explain me, if this function merely converts the
> > pansharpened VRT  XML to VRT dataset
> Yes
> > or does it actually pansharpens the
> > image using multispectral and panchromatic inputs
> No, you have to read the content of the VRT dataset with GDAL RasterIO()
> API or translate it to another format like GTiff with GDALCreateCopy() for
> example.
> > . If the latter is true
> > please let me know how to generate such an XML and what it should
> > consist of.
> See also
> http://www.gdal.org/gdal_vrttut.html#gdal_vrttut_pansharpen
> And also http://www.gdal.org/gdal_pansharpen.html if you don't need to
> embed that in your program but just run as an external program.
> Even
> Spatialys - Geospatial professional services http://www.spatialys.com
