[gdal-dev] Utilities as a library, C API
Even Rouault even.rouault at spatialys.com
Wed Oct 19 12:55:09 PDT 2016
Ivan,
The fact that GDALTranslateOptions is opaque is a design decision that was the
outcome of the discussion phase of RFC 59. It was thought that it would be
difficult to have a stable C structure that could be also extented in the future
without becoming too messy. For example regarding old options that would have
been generalized into newer syntax. Hence the decision to have a minimal
string based interface that takes the same arguments than the command line
strings that lead to RFC 59.1.
So it is up to you to build a nicer API on top of this and build the string
array (that's what the python bindings do for example). Note that the strings
must be split like the arguments of the main(), ie. { "-of", "GTiff", NULL }.
Even
http://www.spatialys.com
