[gdal-dev] Utilities as a library, C API
Even Rouault even.rouault at spatialys.com
Thu Oct 20 13:26:12 PDT 2016
On Thursday 20 October 2016 15:03:03 Ivan Lucena wrote:
> Hi Even,
> OK. It is what it is. I guess.
> I wrote a little test code:
> #include <gdal.h>
> #include <gdal_utils.h>
> int main( int argc, char** argv )
>    char* papszArgv[1024];
>    int i = 0;
>    const char*     pszSrcFilename = "rgbsmall.tif";
>    const char*     pszDstFilename = "test90.tif";
>    GDALDatasetH    hSrcDataset = NULL;
>    GDALDatasetH    hDstDataset = NULL;
>    GDALTranslateOptions* psOptions = NULL;
>    GDALAllRegister();
>    papszArgv[i++] = "-of";
>    papszArgv[i++] = "GTIFF";
>    papszArgv[i++] = "-b";
>    papszArgv[i++] = "3";
>    papszArgv[i++] = "2";
>    papszArgv[i++] = "1";
>    papszArgv[i++] = "-srcwin";
>    papszArgv[i++] = "10";
>    papszArgv[i++] = "30";
>    papszArgv[i++] = "-co";
>    papszArgv[i++] = "BLOCKXSIZE=4";
>    papszArgv[i++] = "BLOCKYSIZE=4";
>    papszArgv[i++] = NULL;
>    psOptions   = GDALTranslateOptionsNew( papszArgv, NULL );
>    hSrcDataset = GDALOpen( pszSrcFilename, GA_ReadOnly );
>    hDstDataset = GDALTranslate( pszDstFilename, hSrcDataset, psOptions, NULL
>    GDALTranslateOptionsFree( psOptions );
>    GDALClose( hSrcDataset );
>    GDALClose( hDstDataset );
> And I can say that it does work as expected. Maybe we should put that
> example somewhere on the wiki.
> I found to interesting issues. That is just a C application using the GDAL C
> API but I could only compile with g++, not with gcc.
Could you be more specific about the error you got ? It should be usable from
pure C, but I'm not 100% positive this has been tested
> The GTIFF create-option BLOCKXSIZE doesn't seems to work. I tries with
> larger images and it seems like we can only control the number of rows on a
> block (BLOCKYSIZE),  but not the number of columns (BLOCKXSIZE).
BLOCKXSIZE is only taken into account if you also define TILED=YES.
Even
http://www.spatialys.com
