[gdal-dev] New GMLAS (GML Application Schema) in trunk
Even Rouault even.rouault at spatialys.com
Thu Oct 20 14:04:07 PDT 2016
Hi Jukka,
> The XSD schema is massive but GDAL seems to resolve it and it finds huge
> amount of layers from the sample XML files, with geometries where they
> belong to.
You can use -oo REMOVE_UNUSED_LAYERS=YES (and -oo REMOVE_UNUSED_FIELDS=YES) to
get only the relevant layers for what is really in the .xml
> Feels like an awesome work.
Thanks. A big remaining part planned for the next weeks is doing the reverse
operation: given a database with a structure of layers and fields as the ones
exposed by the read side, compose a valid XML file.
Even
http://www.spatialys.com
