[gdal-dev] GDAL/OGR 2.1.2 RC2 Available for Review
Kurt Schwehr schwehr at gmail.com
Thu Oct 20 22:33:32 PDT 2016
Fixed OSM bug I introduced back in January...
https://trac.osgeo.org/gdal/changeset/35846
On Wed, Oct 19, 2016 at 4:44 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> I've generated a new RC because of a regression I just found (fixed per
> https://trac.osgeo.org/gdal/ticket/6691)
> Updated links:
>   http://download.osgeo.org/gdal/2.1.2/gdal-2.1.2RC2.tar.xz
>   http://download.osgeo.org/gdal/2.1.2/gdal-2.1.2RC2.tar.gz
>   http://download.osgeo.org/gdal/2.1.2/gdal212RC2.zip
>   http://download.osgeo.org/gdal/2.1.2/gdalautotest-2.1.2RC2.tar.gz
>   http://download.osgeo.org/gdal/2.1.2/gdalautotest-2.1.2RC2.zip
> The changes since 2.1.2RC1 are:
> * /vsimem/: fix potential crash when closing -different- handles pointing
> to the
> same file from different threads (fixes #6683)
> * Fix multi-threading issues in read/write scenarios (fixes #6684)
> * ILI1: fix crash in OGRILI1Layer::JoinSurfaceLayer() when the multicurve
> of
> the feature of the poSurfaceLineLayer layer is empty (fixes #6688)
> * GPKG/SQLite/PG/FileGDB/MEM: properly set/reset field subtype with
> AlterFieldDefn() (fixes #6689)
> * Fix regression in PLScenes V1 raster random access. Add a
> CPL_VSIL_CURL_ALLOWED_FILENAME config option to solve that (fixes #6691)
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161020/0e28b6cd/attachment.html>
