[gdal-dev] gdal_translate to Rasterlite and (missing) srs
Helmut Kudrnovsky hellik at web.de
Mon Oct 24 10:25:45 PDT 2016
hi Even,
Even Rouault-2 wrote
> Helmut,
>> is this intentional that there is no srs by a simple gdal_translate of a
>> geotiff to a Rasterlite db?
> From what I can see the driver doesn't handle adding a new entry in the
> spatial_ref_sys table if there's no AUTHORITY node, such as in your use
> case.
> From what I can see, it also probably doesn't properly support creating
> entries in spatial_ref_sys with Spatialite 4 layout (the driver has been
> likely developped during Spatialite 3 era)
> It is "intentional" in the meaning that this wasn't implemented, but could
> potentially be added. Could be worth a ticket in Trac.
thanks for the explanations. ticket opened in trac #6697.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-translate-to-Rasterlite-and-missing-srs-tp5292361p5292390.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
