[gdal-dev] gdalwarp vs gdal_translate for resizing images
Even Rouault even.rouault at spatialys.com
Thu Oct 27 06:48:15 PDT 2016
Le jeudi 27 octobre 2016 15:02:11, Travis Kirstine a écrit :
> I've been looking at resampling high resolution orthophoto images (0.10m)
> using gdalwarp vs gdal_translate to a lower resolution
> gdalwarp  -co TILED=YES -srcnodata "0 0 0" -dstnodata "0 0 0" -tr 2 2   -r
> bilinear in.tif warp_2m_bilinear.tif
> compared to
> gdal_translate -co TILED=YES -a_nodata 0 -tr 2 2  -r bilinear input.tif
> translate_2m_bilinear
> It appears to me that gdal_translate produces a much "better" result with
> reduced aliasing.  Why would the results differ?
Does gdalinfo on the output of both files report the same spatial extent ?
gdalwarp and gdal_translate have different logic to compute it when not
explicitly mentionned.
http://www.spatialys.com
