[gdal-dev] splitting other_tags from .osm file
Even Rouault even.rouault at spatialys.com
Sat Oct 29 13:04:50 PDT 2016
Le samedi 29 octobre 2016 22:03:29, jratike80 a écrit :
> Hi,
> Have you tried "all_tags" http://www.gdal.org/drv_osm.html?  Shapefiles are
> poor as target format because it limits the name of the tag to 10
> characters, and the length of the value to 255 characters. I recommend to
> use Spatialite or GeoPackage instead.
all_tags will not do what Djordge wants. It is just a concatenation of all
tags in a single field with hstore formatting.
> -Jukka Rahkonen-
> http://osgeo-org.1560.x6.nabble.com/gdal-dev-splitting-other-tags-from-osm
> -file-tp5293451p5293456.html Sent from the GDAL - Dev mailing list archive
> at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
