[gdal-dev] splitting other_tags from .osm file
Djordje Spasic issworld2000 at yahoo.com
Sat Oct 29 14:50:22 PDT 2016
Thank you Even.
> Why notjust experimenting ? This would be clearer than any explanations.
I did. But I do not understand the results.
Fore example if for "other_tags=yes" for a single shape I got the string previously mentioned:
"addr:postcode"=>"80636","addr:street"=>"Marlene-Dietrich-Strasse"
But if I set the "all_tags=yes", then for the same shape, I get the following all_tags string:
"addr:postcode"=>"80636","addr:street"=>"Marlene-Dietrich-Straße","building"=>"yes"
So only the additional: "building"=>"yes" tag is given.
Which makes me confused what is the difference between other_tags and all_tags.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161029/f9fe8079/attachment-0001.html>
