[gdal-dev] splitting other_tags from .osm file
Djordje Spasic issworld2000 at yahoo.com
Sun Oct 30 05:55:15 PDT 2016
Thank you for the reply Etienne,
I am not interested in using QGIS. I am limited to OGR2OGR.exe for now.
> As Even said, there is no way to get all tags as a separate field only with ogr2ogr. The 'all_tags' flag will use the HSTORE only.
Yes, I understood that from Even's reply.
Jukka mentioned all_tags, of which I haven't been aware of.
So my issue now is: what is the difference between other_tags and all_tags?
Thank you.
Regards,
Djordje
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161030/3571c9da/attachment.html>
