[gdal-dev] splitting other_tags from .osm file
Andre Joost andre+joost at nurfuerspam.de
Sun Oct 30 09:57:37 PDT 2016
Am 30.10.2016 um 13:55 schrieb Djordje Spasic:
> Jukka mentioned all_tags, of which I haven't been aware of.
> So my issue now is: what is the difference between other_tags and all_tags?
other_tags includes all tags that are **not** covered by the attribute
fields list in osmconf.ini.
all_tags includes really all tags of a feature, even if they are already
in their respective column listed in osmconf.ini (like building or
highway usually are).
It might be necessary to rename addr:postcode to addr_postcode or
postcode to avoid further problems with shapefile specifications. See
http://support.esri.com/technical-article/000005588
HTH,
André Joost
