[gdal-dev] gdal configuration parameters settings...
Ari Jolma ari.jolma at gmail.com
Sun Sep 4 21:56:58 PDT 2016
05.09.2016, 03:27, JIA Pei kirjoitti:
> If I just move forward without enabling all other configurations,
> namely, still keep all "no"s, and do "make -j8", I got the following
> error message:
> libtool: compile: g++ -DHAVE_AVX_AT_COMPILE_TIME
> -DHAVE_SSSE3_AT_COMPILE_TIME -DHAVE_SSE_AT_COMPILE_TIME -g -O2 -Wall
> -Wextra -Winit-self -Wunused-parameter -Wformat
> -Werror=format-security -Wno-format-nonliteral -Wlogical-op -Wshadow
> -Werror=vla -Wfloat-conversion -Wmissing-declarations
> -Wnon-virtual-dtor -Woverloaded-virtual -fno-operator-names
> -I/home/jiapei/Downloads/rsgis/OSGeo/gdal/gdal/port -DGDAL_COMPILATION
> -c -I../../port Huffman.cpp -o ../../o/Huffman.o >/dev/null 2>&1
What you don't get it is the error message. Could you run just this
command without the trailing >/dev/null, which eats the error message?
Ari
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160905/d6694766/attachment.html>
