[gdal-dev] minor correction for drv_libkml.html [bash-script] neeted
Even Rouault even.rouault at spatialys.com
Sat Sep 10 03:21:25 PDT 2016
Le samedi 10 septembre 2016 12:05:36, Mark Johnson a écrit :
> While adding support for LIBKML to my gdal configuration
> - I attempted to use the sample bash-script to insure that it worked
> correctly
Fixed. Thanks (I actually removed this copyright line since it was
inappropriately added by a script to update copyright lines)
> It failed with a syntax error, caused in line 3 of the script:
> > #!/bin/bash
> > # Copyright (c) 2010, Brian Case
> >  * Copyright (c) 2010-2014, Even Rouault
> > # Permission
> > needs to be changed to:
> > #!/bin/bash
> > # Copyright (c) 2010-2014, Even Rouault
> > # Permission
> > to run without error.
> Mark Johnson, Berlin Germany
http://www.spatialys.com
