[gdal-dev] VRT derived band pixel functions written in Python
James Ramm jamessramm at gmail.com
Tue Sep 13 12:22:20 PDT 2016
I think you can call SWIG with the -threads argument on the command line so
it will always release the GIL. Could be an easy option if it works
On Tuesday, 13 September 2016, Even Rouault <even.rouault at spatialys.com>
wrote:
> Le mardi 13 septembre 2016 11:07:39, Rutger a écrit :
> > I overlooked the fact that it still moves through Python, is that the
> > 'only' hurdle preventing parallel IO?
> Not sure to understand your question. But if you have several sources, you
> could potentially do parallelized reading of them from the Python code by
> using Python threads and GDAL Python API. But looking in the SWIG generated
> code, it doesn't seem that SWIG releases the GIL automatically before
> calling
> native code. Hum... So that should probably added manually, at least around
> GDALRasterIO() calls, otherwise you'll get zero perf improvements.
> > Since gdalwarp for example has the
> > -multi flag, it seems as if GDAL is capable of it, or is that a
> > specific/specialized implementation?
> Parallelized I/O doesn't mean much by itself without more context. You may
> want to parallelize reading of different regions of the same dataset, or
> parallelize reading of different datasets. Due to GDAL objects not being
> thread-safe, the first case (reading of different regions of the same
> dataset)
> can be solved with the second one by opening several datasets for the same
> filename.
> Regarding gdalwarp -multi, here's how that works. When you warp a dataset,
> there's a list of all chunks (windows) to be processed that is generated.
> gdalwarp -multi does the following
> Thread I/O                                              Thread computation
> Read data for chunk 1
> Read data for chunk 2                   Do calculations for chunk 1
> Write output of chunk 1                 Do calculations for chunk 2
> Read data for chunk 3
> Write output of chunk 2                 Do calculations for chunk 3
> > Numba has several options which might eliminate using Python during
> > execution. There are c-callbacks:
> > http://numba.pydata.org/numba-doc/dev/user/cfunc.html
> You can also use @jit(nopython=True, nogil=True) and your Python method
> will
> end up being pure native code (provided that you don't use too high level
> stuff
> otherwise the jit'ification will fail with an exception).
> And for code that is not inlined in the VRT, you can also add cache=True so
> that the jit'ification can be reused.
> With all that the cost of the Python layer becomes neglectable (except
> loading
> the Python environment the first time, if not already loaded, but for a
> computation that will be longer than a few seconds, that's not really a big
> deal)
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <javascript:;>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160913/11d5e984/attachment.html>
