[gdal-dev] SQLite driver?
Joaquim Luis jluis at ualg.pt
Wed Sep 14 14:02:59 PDT 2016
Yes, but (that I know) we don't get long stack traces in VS.
Exception thrown at 0x00007FFF88F87788 in osmcoastline.exe: Microsoft C++
exception: gdalcpp::gdal_error at memory location 0x000000CD6E33E090.
Unhandled exception at 0x00007FFF88F87788 in osmcoastline.exe: Microsoft
C++ exception: gdalcpp::gdal_error at memory location 0x000000CD6E33E090.
The program '[37264] osmcoastline.exe' has exited with code 0 (0x0).
I can see why it crashes but why it happens. To start with the code is
completely mysterious for me
class Driver : private init_library {
gdal_driver_type* m_driver;
public:
Driver(const std::string& driver_name) :
init_library(),
#if GDAL_VERSION_MAJOR >= 2
m_driver(GetGDALDriverManager()->GetDriverByName(driver_name.c_str())) {
#else
m_driver(OGRSFDriverRegistrar::GetRegistrar()->GetDriverByName(driver_name.c_str()))
#endif
if (!m_driver) {
throw gdal_error(std::string("unknown driver: '") + driver_name + "'",
OGRERR_NONE, driver_name);
m_driver is defined as a function, which is than tested to be NULL (and it
is) and a crash follows.
> A stack trace would give others a chance to possibly spot what the crash
> is.
> On Wed, Sep 14, 2016 at 11:31 AM, Joaquim Luis <jluis at ualg.pt> wrote:
>> OK, clean & rebuilt (as I (thought) did before) and I can see the
>> SQLite driver now.
>> However, the osmcoastline still crashes. Unfortunately, it's too damn
>> C++ for me to debugg.
>>> Le mercredi 14 septembre 2016 19:43:22, Joaquim Luis a écrit :
>>>> Sorry, my bad. When I thought I was using gisinternals I was actually
>>>> using my build. Gisinternals does show the SQLite driver.
>>>> But one of my points still holds. If the Walker shows me that
>>>> sqlite3.dll
>>>> is a dependency than why the SQLite driver is not available?
>>> You mentionned that you "(re)build" GDAL with sqlite, so I assume you
>>> added it
>>> after a first build. So I suspect that some files didn't get
>>> recompiled. The
>>> safest way if not already done is to clean and rebuild.
>>> Otherwise, mostly for a quick check, you may just 'touch'
>>> ogr/ogrsf_frmts/generic/ogrregisterall.cpp but you'll probably miss a
>>> few files
>>> that will benefit from sqlite being now available. So the clean &
>>> rebuild path
>>> is the safest ultimately.
>>>>> Hmm, several (weird) things.
>>>>> 1. I'm using  GnuWin ports for unix commands. And:
>>>>>    - this works
>>>>>          gdalinfo --formats | sort
>>>>>    - this not (output is empty)
>>>>>          ogfinfo --formats | sort
>>>>>   Same thing for 'grep'
>>>>> 2. To check I'm using gisinternals and same thing as my build.
>>>>>   ogrinfo --formats  shows no SQLite driver
>>>>> 3. The program I'm trying to build/run crashes at this line
>>>>>    https://github.com/osmcode/osmcoastline/blob/master/include/gdalcpp.hp
>>>>>    p#L132 (no idea why it crashes) apparently because it doesn't
>>>>> find the
>>>>> SQLite driver (driver_name == 'SQLite')
>>>>>> ogrinfo --formats | grep -i lite
>>>>>>  SQLite -vector- (rw+v): SQLite / Spatialite
>>>>>> On Wed, Sep 14, 2016 at 9:32 AM, Joaquim Luis <jluis at ualg.pt> wrote:
>>>>>>> Sorry Even that you are bombed with so many questions.
>>>>>>> I have (re)build GDAL with sqlite and can confirm with The
>>>>>>> (Dependency) Walker that the sqlite3.dll is a gdal.dll dependency.
>>>>>>> However,
>>>>>>> gdalinfo --formats
>>>>>>>  Rasterlite -raster- (rws): Rasterlite
>>>>>>>  SAFE -raster- (rov): Sentinel-1 SAR SAFE Product
>>>>>>>  SAR_CEOS -raster- (rov): CEOS SAR Image
>>>>>>>  SDTS -raster- (rov): SDTS Raster
>>>>>>>  SENTINEL2 -raster- (rovs): Sentinel 2
>>>>>>>  SGI -raster- (rw+): SGI Image File Format 1.0
>>>>>>>  SRTMHGT -raster- (rwv): SRTMHGT File Format
>>>>>>>  TIL -raster- (rov): EarthWatch .TIL
>>>>>>> does not show the SQLite driver and indeed a program that I'm
>>>>>>> building
>>>>>>> that needs to link with GDAL (osmcoastline) crashes when it doesn't
>>>>>>> find >>>that driver.
>>>>>>> Joaquim
>>>>>>> _______________________________________________
>>>>>>> gdal-dev mailing list
>>>>>>> gdal-dev at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>>>> http://schwehr.org
> http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160914/24eee472/attachment.html>
