[gdal-dev] SQLite driver?
    Joaquim Luis
    jluis at ualg.pt
    Wed Sep 14 14:55:02 PDT 2016
FWIW, my reply with an attached image is waiting for approval.
> I haven't done serious Windows coding since the NT days, but I found
> this.  Sounds like this will do it and then you can load the dump in
> visual >studio and get the stack track, yes?
> Anyone who actually uses windows + visualstudio want to comment?
> -kurt
> http://cwspencer.co.uk/blog/2012/10/getting-useful-c-exception-information-from-visual-studio/
> Which down at the bottom says:
> You can get WER to generate full crash dumps when your program crashes
> and you don’t have a debugger >attached by creating the DWORD registry
> keyHKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Windows Error
> Reporting>\LocalDumps\DumpType and setting it to 1 (for mini dumps) or 2
> (for full dumps). This will create a dump file >in
> %LOCALAPPDATA%\CrashDumps when your program crashes which you can import
> into Visual Studio. This is >particularly useful when you are testing on
> someone else’s machine where you can’t debug directly.
> On Wed, Sep 14, 2016 at 2:02 PM, Joaquim Luis <jluis at ualg.pt> wrote:
>> Yes, but (that I know) we don't get long stack traces in VS.
>> Exception thrown at 0x00007FFF88F87788 in osmcoastline.exe: Microsoft
>> C++ exception: gdalcpp::gdal_error at memory location
>> >>0x000000CD6E33E090.
>> Unhandled exception at 0x00007FFF88F87788 in osmcoastline.exe:
>> Microsoft C++ exception: gdalcpp::gdal_error at memory location
>> >>0x000000CD6E33E090.
>> The program '[37264] osmcoastline.exe' has exited with code 0 (0x0).
>> I can see why it crashes but why it happens. To start with the code is
>> completely mysterious for me
>> class Driver : private init_library {
>> gdal_driver_type* m_driver;
>> public:
>> Driver(const std::string& driver_name) :
>> init_library(),
>> #if GDAL_VERSION_MAJOR >= 2
>> m_driver(GetGDALDriverManager()->GetDriverByName(driver_name.c_str())) {
>> #else
>> m_driver(OGRSFDriverRegistrar::GetRegistrar()->GetDriverByName(driver_name.c_str()))
>> #endif
>> if (!m_driver) {
>> throw gdal_error(std::string("unknown driver: '") + driver_name + "'",
>> OGRERR_NONE, driver_name);
>> m_driver is defined as a function, which is than tested to be NULL (and
>> it is) and a crash follows.
>>> A stack trace would give others a chance to possibly spot what the
>>> crash is.
>>> On Wed, Sep 14, 2016 at 11:31 AM, Joaquim Luis <jluis at ualg.pt> wrote:
>>>> OK, clean & rebuilt (as I (thought) did before) and I can see the
>>>> SQLite driver now.
>>>> However, the osmcoastline still crashes. Unfortunately, it's too damn
>>>> C++ for me to debugg.
>>>>> Le mercredi 14 septembre 2016 19:43:22, Joaquim Luis a écrit :
>>>>>> Sorry, my bad. When I thought I was using gisinternals I was
>>>>>> actually
>>>>>> using my build. Gisinternals does show the SQLite driver.
>>>>>> But one of my points still holds. If the Walker shows me that
>>>>>> sqlite3.dll
>>>>>> is a dependency than why the SQLite driver is not available?
>>>>> You mentionned that you "(re)build" GDAL with sqlite, so I assume
>>>>> you added it
>>>>> after a first build. So I suspect that some files didn't get
>>>>> recompiled. The
>>>>> safest way if not already done is to clean and rebuild.
>>>>> Otherwise, mostly for a quick check, you may just 'touch'
>>>>> ogr/ogrsf_frmts/generic/ogrregisterall.cpp but you'll probably miss
>>>>> a few files
>>>>> that will benefit from sqlite being now available. So the clean &
>>>>> rebuild path
>>>>> is the safest ultimately.
>>>>>>> Hmm, several (weird) things.
>>>>>>> 1. I'm using  GnuWin ports for unix commands. And:
>>>>>>>    - this works
>>>>>>>          gdalinfo --formats | sort
>>>>>>>    - this not (output is empty)
>>>>>>>          ogfinfo --formats | sort
>>>>>>>   Same thing for 'grep'
>>>>>>> 2. To check I'm using gisinternals and same thing as my build.
>>>>>>>   ogrinfo --formats  shows no SQLite driver
>>>>>>> 3. The program I'm trying to build/run crashes at this line
>>>>>>>    https://github.com/osmcode/osmcoastline/blob/master/include/gdalcpp.hp
>>>>>>>    p#L132 (no idea why it crashes) apparently because it doesn't
>>>>>>> find the
>>>>>>> SQLite driver (driver_name == 'SQLite')
>>>>>>>> ogrinfo --formats | grep -i lite
>>>>>>>>  SQLite -vector- (rw+v): SQLite / Spatialite
>>>>>>>> On Wed, Sep 14, 2016 at 9:32 AM, Joaquim Luis <jluis at ualg.pt>
>>>>>>>> wrote:
>>>>>>>>> Sorry Even that you are bombed with so many questions.
>>>>>>>>> I have (re)build GDAL with sqlite and can confirm with The
>>>>>>>>> (Dependency) Walker that the sqlite3.dll is a gdal.dll
>>>>>>>>> dependency.
>>>>>>>>> However,
>>>>>>>>> gdalinfo --formats
>>>>>>>>>  Rasterlite -raster- (rws): Rasterlite
>>>>>>>>>  SAFE -raster- (rov): Sentinel-1 SAR SAFE Product
>>>>>>>>>  SAR_CEOS -raster- (rov): CEOS SAR Image
>>>>>>>>>  SDTS -raster- (rov): SDTS Raster
>>>>>>>>>  SENTINEL2 -raster- (rovs): Sentinel 2
>>>>>>>>>  SGI -raster- (rw+): SGI Image File Format 1.0
>>>>>>>>>  SRTMHGT -raster- (rwv): SRTMHGT File Format
>>>>>>>>>  TIL -raster- (rov): EarthWatch .TIL
>>>>>>>>> does not show the SQLite driver and indeed a program that I'm
>>>>>>>>> building
>>>>>>>>> that needs to link with GDAL (osmcoastline) crashes when it
>>>>>>>>> doesn't
>>>>>>>>> find >>>that driver.
>>>>>>>>> Joaquim
>>>>>>>>> _______________________________________________
>>>>>>>>> gdal-dev mailing list
>>>>>>>>> gdal-dev at lists.osgeo.org
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>>>>>> http://schwehr.org
>>> http://schwehr.org
> http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160914/6d63ba3a/attachment.html>
