[gdal-dev] SQLite driver?
Joaquim Luis jluis at ualg.pt
Fri Sep 16 08:28:36 PDT 2016
Yes, it had a small image attached.
But never mind, I ended up finding that the crash resulted from the fact
that some other gdal.dll without sqlite driver managed to get in the way.
The bad new was that, once this solved, I got another crash latter but
there is nothing in it that I can relate to gdal, so issue is closed here.
Thanks to people that tried to help.
Joaquim
> On 2016-09-14 6:55 PM, Joaquim Luis wrote:
>> FWIW, my reply with an attached image is waiting for approval.
> Joaquim, I checked in the mailman backend and I don't see a message
> being held.  But for sure always always when using mailing lists never
> try attaching things, for example if you need to include an image just
> use an external service like http://pasteboard.co/ and include the url
> to that image, in your response.
> -jeff
