[gdal-dev] ERROR 6: No translation for Lambert_Conformal_Conic to PROJ.4 format is known.
Helmut Kudrnovsky hellik at web.de
Fri Sep 16 13:52:15 PDT 2016
hi,
I have vector dataset [1] in EPSG:31254.
then I do ogr2ogr -s_srs EPSG:31254 -t_srs EPSG:31287 ....
if I do testepsg EPSG:31287, I get following +proj4 string:
PROJ.4 rendering of [EPSG:31287] = +proj=lcc +lat_1=49 +lat_2=46 +lat_0=47.5
+lon_0=13.33333333333333 +x_0=400000 +y_0=400000 +ellps=bessel
+towgs84=577.326,90.129,463.919,5.137,1.474,5.297,2.4232 +units=m +no_defs
when I do: testepsg of the ogr2ogr'ed shapefile prj file:
testepsg Gesamtgewaessernetz_v11_Tirol_epsg31287.prj
known.
PROJ.4 rendering of [Gesamtgewaessernetz_v11_Tirol_epsg31287.prj] =
is this normal? any idea?
[1] https://www.tirol.gv.at/data/datenkatalog/umwelt/gewaessernetz/
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/ERROR-6-No-translation-for-Lambert-Conformal-Conic-to-PROJ-4-format-is-known-tp5286399.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
