[gdal-dev] ERROR 6: No translation for Lambert_Conformal_Conic to PROJ.4 format is known.
Helmut Kudrnovsky hellik at web.de
Fri Sep 16 14:21:57 PDT 2016
Hi Even
Even Rouault-2 wrote
> Helmut,
>> when I do: testepsg of the ogr2ogr'ed shapefile prj file:
>> testepsg Gesamtgewaessernetz_v11_Tirol_epsg31287.prj
>> known.
>> PROJ.4 rendering of [Gesamtgewaessernetz_v11_Tirol_epsg31287.prj] =
>> is this normal?
> Yes. testepsg foo.prj expects a .prj file conforming to OGC WKT, whereas a
> .prj
> file generated by the Shapefile driver will follow ESRI WKT.
> testepsg (or gdalsrsinfo)
> ESRI::Gesamtgewaessernetz_v11_Tirol_epsg31287.prj
> will report
> PROJ.4 : '+proj=lcc +lat_1=49 +lat_2=46 +lat_0=47.5
> +lon_0=13.33333333333333
> +x_0=400000 +y_0=400000 +ellps=bessel +units=m +no_defs '
> OGC WKT :
> PROJCS["MGI_Austria_Lambert",
>     GEOGCS["GCS_MGI",
>         DATUM["Militar_Geographische_Institute",
>             SPHEROID["Bessel_1841",6377397.155,299.1528128]],
>         PRIMEM["Greenwich",0],
>         UNIT["Degree",0.017453292519943295]],
>     PROJECTION["Lambert_Conformal_Conic_2SP"],
>     PARAMETER["standard_parallel_1",49],
>     PARAMETER["standard_parallel_2",46],
>     PARAMETER["latitude_of_origin",47.5],
>     PARAMETER["central_meridian",13.33333333333333],
>     PARAMETER["false_easting",400000],
>     PARAMETER["false_northing",400000],
>     UNIT["Meter",1]]
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at .osgeo
Thanks for the  testepsg (or gdalsrsinfo) ESRI::... hint!
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/ERROR-6-No-translation-for-Lambert-Conformal-Conic-to-PROJ-4-format-is-known-tp5286399p5286405.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
