[gdal-dev] kmz (KMLSUPEROVERLAY) back to a georeferenced raster
Even Rouault even.rouault at spatialys.com
Sat Sep 17 13:41:27 PDT 2016
Le samedi 17 septembre 2016 22:34:35, Helmut Kudrnovsky a écrit :
> hi,
> I have a bunch of of kmz with kmlsuperoverlay (i.e. inside the zipped file
> a kml file (geo)referencing jpg's).
> is there an easy way back from such a kmz to a georeferenced raster (e.g.
> geotiff) ?
gdalinfo / gdal_translate should be able to run on a kmz file, although I
wouldn't exclude there might be some formulations  of kml/kmz superoverlay
that the driver might not handle.
gdal_translate your.kmz out.tif
> best regards
> Helmut
> http://osgeo-org.1560.x6.nabble.com/kmz-KMLSUPEROVERLAY-back-to-a-georefer
> enced-raster-tp5286480.html Sent from the GDAL - Dev mailing list archive
> at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
