[gdal-dev] Some packages are NOT able to be configured?
Even Rouault even.rouault at spatialys.com
Mon Sep 26 01:33:47 PDT 2016
Le lundi 26 septembre 2016 04:10:06, JIA Pei a écrit :
> Hi, all:
> I actually would like to enable as many packages as possible for gdal, but
> it seems even if I strictly following "*./configure --hel*p", some packages
> are still NOT able to be configured correctly.
> For instance, *HDF5* (instead of *HDF4*)?
> I'm using Ubuntu 16.04.1, and it seems the default *gdal* from repository
> is based on *HDF4* ??
> That's why I would like to build *gdal* by myself.
The GDAL package from
https://launchpad.net/~ubuntugis/+archive/ubuntu/ubuntugis-unstable/ has the
HDF5 dependency.
If you look at the debian/rules file of
unstable/+files/gdal_2.1.0+dfsg-1~xenial0.debian.tar.gz there's a trick to find
the HDF5 lib which is at a quite particular location :
--with-hdf5=/usr/lib/$(DEB_HOST_MULTIARCH)/hdf5/serial
where $(DEB_HOST_MULTIARCH) will evaluate to x86_64-linux-gnu in your case.
http://www.spatialys.com
